Vin / serial # issue confusion
I Bought an 883 motor the other day , was told Frame was totaled in wreck "cracked/ busted frame" so he had pulled motor and scrapped frame and wheels ... and no title anymore " motor on a shelf a year or so" ... found some numbers on crank case " lower front right " all numbers no letters 10 numbers only ... and I found another number set/thing " *CAM92026251* ... so I'm cofused on exactly what motor , size , manu date , etc. ....and how to get title without a vin# ... and not matching a frame and motor #'s1
Received 1,632 Likes
Welcome from NC.
Not sure when the bike/motor was built, but after 1970 the real VIN is on the frame and the motor had an abbreviated VIN. You might be SOL on the VIN, but check this out
http://www.harley-performance.com/harley-vin.html
Ok... so all I need is a frame with a good title and build from there ? And if I read correct in all of that should there not be letters in the 10 digits on the motor ??? The first 7 should be if I'm correct 1HD1CAM....and the 10 on case should have some numbers and letters ??? I'm lost ..
The Vehicle Identification Number and the Engine Serial Number are two separate things...
There is no requirement that the engine serial number match the VIN on the frame.
Harley just happens to do it that way, most vehicle manufacturers do not.
The VIN will be the 17 digit number on the frame you are using now.
I do not have a frame as of yet , I was recently given 2-7 years left to live and my wife asked me what I had on my Bucket list and I only have a few #1 make amends to all family ☆ #2 . Married and a good family ☆ #3 own another truck " instead of cars " ☆ #4 own my last and final motorcycle " Harley Davidson" ...... and being I do not have the money to go buy a big fat Bike I decided to buy or barter and build myself a Harley Davidson , and it has been so much harder to get anything than I had thought , so when I bartered this for that for this and that and finally for a Harley Davidson 883 engine I thought I'm home free and as I'm finding out it may be harder than I can handle .... sorry to put my life out there but it let's you know more of why I ask all these questions ... cause if I can't use this engine I'm back to ground ZERO. AGAIN ....
