Biltwell Clubman handlebars.
Old 07-25-2016, 03:39 PM
wolfman5874's Avatar
wolfman5874
wolfman5874 is offline
Default Biltwell Clubman handlebars.
I would like to order these handlebars. For the "bar type" option, what is non-dimpled?
Do I need to be aware about anything else before purchasing?
https://www.biltwellinc.com/p49/buy/...-1-quot-black/
Old 07-25-2016, 04:09 PM
John Harper's Avatar
John Harper
John Harper is online now
Received 1,982 Likes on 1,351 Posts
There are indented dimples in the bars where the switch wires run though the lever perches. I think the design sucks, because it's easy to pinch wires, and if your bike falls on the throttle side it can also cause wiring damage. JMHO. Look at your existing bars where the controls and wiring goes toward the steering stem. Also, make sure you get "knurled" bars as well, so the riser clamps have a rough surface to grip.
John
Old 07-25-2016, 06:16 PM
sawka's Avatar
sawka
sawka is offline
I know you cant get knurled from biltwell. Also I thought they didnt make clubmans with dimples (biltwell). Personally i dont think it matters and while I do believe it technically modifies the structural integrity I cant imagine by much.
Therefore the question is simple: Do you want your wires to run in the dimples and be a bit more tidy?
Personally I have Biltwell Maynards which dont have the knurling but I think it holds well enough. If you are worried about it you can rough it up with rough grit sandpaper (only in the center) and I imagine it would be similar albeit less adequate for the risor clamp. Just my two cents but I can say I am pleased with the biltwell quality for price.
F86
01-10-2018 02:34 PM
phatjoe
04-19-2014 07:47 AM
Jaystn62
11-14-2011 02:24 PM
cdaxj
03-24-2009 09:24 PM
DrPlastic
11-10-2007 10:22 PM
Quick Reply: Biltwell Clubman handlebars.
