87 octane or 93 octane
The H-D owners manual does not call for 91 it recommends it. There is a world of difference between a requirement and a recommendation.
Why don't they require 91 or higher? Because our nanny government dictates that any vehicle sold for highway use in the US MUST be able to run on 87. That is part of the job that the ECM and nine sensors to take care of.
I have many posts over the years about how I run 87 in 883's, 1200's, TC88's,TC96's, TC103's, TC103HO's, TC110's and TC120's with getting more power, mpg and cooler running.
Collectively I run them 30 to 40K + per year. No pinging no issues. I have over 10K on one TC120 with 87 octane from day one.
It is a process of setting the AFR, iridium plugs, oil cooler, tank lift (cooler heads) high flow intake and stock exhaust that facilitates using E1087 octane.
Octane is not power it is the measurement of a fuels resistance to ignition and burn rate. The higher the number the harder to ignite so less burns during the combustion cycle. The less burned the less BTU's produced the less power made and the more the engine is fouled.
However, if the compression has been raised over stock, the spark advanced as it is from a stage I tune on and the higher performance cams added higher octane becomes a must.
I have been messing with high performance engines for 60 years from muscle cars to Vettes and Vipers. Now I focus on getting the most mpg out of a V twin H-D engine. I have done 25 since 06 with 21 still in the garage. My latest effort is a new Roadster.
Huggerbugger (07-20-2016)
