Help removing voltage regulator with stripped screws
I'm trying to remove a voltage regulator on my 07 883 sporty, however I've run into a tough spot as the screws stripped. I've used the easy outs but was only able to remove one of the screws. Is there any other way to get these things out?
Use a Dremel with a cutting disk, cut a slot into the head 3/4 the depth of the head. Grab a medium to large flat tip, if it fits tight in the slot use it to remove screw, if it is too tight widen slot slightly until it is a tight fit. My flat tips have a square shank, so you can use a wrench for extra leverage if needed. Good luck
db45
06-13-2022 03:48 PM
mi2az
08-07-2011 05:24 PM
