Plug wires for a 1200S
![Wink](https://www.hdforums.com/forum/images/icons/icon12.gif)
Accel sell sets of yellow plug wires which you can admire here. I'm sure they can advise you which kits will work with your bike, or make you up a set. As you have your current plug wires, you can work out which of their wires will work for you. Post pics when you're done!
Thanks for that link. #175099 is the only set that will work but only in black. I found the same set through a wholesaler for $35 but I'm looking for yellow. The coil ends have to be large and the posts in the coil itself is like a spark plug with the end unscrewed. It's a 3/32" threaded stem inside each coil terminal. Not your average configuration for a coil wire.
dwyleecoyote
09-21-2011 08:46 PM
