largest rear tire size?
05-20-2007, 12:17 AM
whats the largest rear tire size you can put on a 2007 1200 nightster? i assume that the other 1200xl would be able to use the same?
05-20-2007, 01:17 AM
RE: largest rear tire size?
I believe the swingarm is the same size as the Custom. With that being said, you can put an 18"x3.5" wheel with a 160 tire. Thats the biggest you can go on any 2005+ Sportster.....I would make sure its going to fit the fender of the Nightster...that I am not sure about.
05-20-2007, 02:30 AM
what's the stock size on a custom? Is this much bigger? I remember reading the 2005 model year included a 1" wider rear axle then previous years.
05-20-2007, 02:32 AM
Factory on a '05 Custom is 150/80 - 16, the axle on the '05 is 1" diameter, up from 3/4" on previous years not 1" wider.
rauchman
09-28-2015 09:13 AM
FlaTriker
05-06-2015 05:29 PM
river rat
08-09-2011 07:30 PM
call-me-hoss
02-22-2009 10:09 AM
lowleveldriver
04-28-2008 03:38 PM
1200 ,
2007 ,
883 ,
biggest ,
hd ,
largest ,
nightster ,
put ,
rear ,
size ,
sizes ,
stock ,
tire ,
tires ,
wheel
