exhuast NUTS
exhuast NUTS
any one else have issues with rounding/ crewing up your exhaust flange bolts?
I installed a new exhaust and had the front top flange nut come loose, so after re tightening, it just got all chewed up, so if it loosen up again. I may just get some lock washers and some nice great 8 nuts as not to worries about over tightening. suggestions?
They are grade 8 and must be properly torqued to spec's and by the procedure outlined in the service manual.
Do one to a specified torque they the other to full torque then back to the first one to full torque.
How do you bugger up a hex nut that is only torqued to about the same as the spark plug?
Their torque value is low as to allow some flexibility.
I also use 1/4" socket tools for the front exhaust for better clearance.
I agree with that 100% to include using 1/4 drive sockets.
Thanks for the info ill check out your nuts
