Gas tank
Gas tank
My father in law passed away and we got his 2003 883 sporty. He did some customization and mods to it. One that is a big deal is he put on a bigger gas tank. My wife now rides it and the other day we were about 2 miles from home, and it spit and sputtered and died. We flipped over to reserve (carbs) and it started and got it home. We put on about 100 miles and figured it was about out of gas. I only put in 2 gallons, and it is probably a 5 gallon tank. I am not familiar with this tank, as it has 2 gas caps. I assume it is one tank and fuel gets used from the entire tank.? I have only filled it from the right side cap. Is there something I need to check? I am thinking of pulling the tank and seeing what is up. Any thoughts or suggestion s before I pull tank? A bit confused at this point.
If it has split tanks , then there is a small crossover fuel line.
If you fill right side only, the pump will shut off before the gas can get to the left side.
result ? only the right tank get's gas and the left one will finally get some = half tanks
fill the left side first, "replace the left cap", then fill the right tank.
(if you leave off the left cap it will overflow as you fill the right"
Received 5,424 Likes
First, we need pics.
Second, take the other gas cap off, is it a dummy or does it go to the tank.
Third, see if you have a crossover line connecting the bottom fronts of the two tanks.
My guess (without pics) is you have a one piece tank, both gas caps may be functional, leading to the same tank. Perhaps the petcock is not at a low spot which is resulting in you not being able to utilize all of the gas in the tanks. Did you look inside before filling it up? Was it low or half full. Do you have a tank lift kit?
Chances of some one welding brackets to the frame to mount real two piece tanks are unlikely with the current aftermarket tanks available. If the bike was older it could be, but considering the vintage I would be surprised. Again, pics and lots of 'em.
sammer4u (05-03-2016)
Truley split tanks will have two gas caps allowing you to fill each side independently. These days those tanks would be considered "Old School". Modern tanks are one piece and have a crossover line that equalizes both sides of the tank. This is to compensate for the valley on the tank that saddles the frame. Harley, to keep the nostalgic look of the tank, either installs a fuel gauge that looks like a gas cap or dummy gas cap on the left hand side of the tank.
Good pics. That is a one piece tank with two gas caps for filling it up. If the bike is level does not matter which one you use it all goes to the same place. If on the kick stand, use the right side for maximum fill up. The fuel line at the front of the tank is the crossover that helps the fuel get from one side of the tank to the other due to the tunnel at the frame.
Overall you probably did not fill the bike up completely. And maybe that tank is not 5 gallons, could be more like 3.5 or 4. Check this listing from J&P:
http://www.jpcycles.com/catalog/2015...?entrypage=705
It looks like your tank, they list it as 3.9 gallons.
sammer4u (05-05-2016)
ersee36
18
05-01-2024 06:01 PM
