No more messy oil change, free tool
I did that based on someone's recommendation here.. It captured a lot of the oil but some did drip on the frame. The bottle can't go under the filter completely becuase there is a casting part of the block under the oil filter which is almost flush with the filter sealing surface.. Am I the only one who experienced this??
BTW - iasporty - your sig pic looks like your carrying an upside down garbage can on your back seat!!
I use a 1L bottle.
denisl, if you still have oil on the frame, you are not doing it right. You have to place the bottle very close to the engine block. The oil change I did this morning didn't even have a drop of oil, go figure. I used to use brake clean to clean it after, not anymore.
