front brake caliper? which one?
Old 04-18-2016, 01:55 PM
drinktothat421's Avatar
drinktothat421
drinktothat421 is offline
Default front brake caliper? which one?
So im planning on getting the stock xr1200 left break caliper. but wanted to see if its worth getting either the brembo vrod caliper, or just a after market arllen ness caliper. any one have information on them.
Old 04-18-2016, 02:07 PM
Mr_Taipan's Avatar
Mr_Taipan
Mr_Taipan is offline
I went with the XR12 one on my Iron and I'm very happy with it. When i was first considering the upgrade I found there are conversion brackets about so you can use other Brembo calipers. Also another recommended one is the Harrisson Billet 6 pot. Some more food for thought...
Old 04-18-2016, 03:21 PM
drinktothat421
I will most likly go with the xr since it seems like the best and easier swap. but i Do like the look of the vrod caliper. and if its a straight swap like the xr i was hoping to find out.
Old 04-18-2016, 03:45 PM
drinktothat421
after a few google searches. it seems like the vrod caliper needs or may need a bigger/more volume MC and the vrod rotor ! due to it being one large piston(idk) and the xr caliper uses a stock sporty rotor. So the xr caliper seems over all the easiest. so xr
Old 04-18-2016, 04:50 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,198 Likes on 1,684 Posts
search google for "Brembo Caliper Install...Lot of pics"
can't post link because hd forums does not allow linking to certain other forums....
Old 04-18-2016, 05:41 PM
shiftace's Avatar
shiftace
shiftace is offline
The Brembo caliper is also best used with the larger 11.8 rotor. It'll work on the 11.5 stocker but doesn't grab the outermost edge. The XR caliper will work just fine with the 11.5 rotor you already have. Plus it looks a lot nicer IMHO
Old 04-18-2016, 05:55 PM
Mr_Taipan's Avatar
Mr_Taipan
Sure, just trying to show you a few more options for your considerations.
Old 04-18-2016, 06:46 PM
drinktothat421
yes you were very helpful and if anyone has links to a aftermarket kits, i wouldn't mind looking at.
Old 04-20-2016, 01:44 PM
splattttttt's Avatar
splattttttt
splattttttt is offline
I will be swapping the stock single on my wifes superlow with the XR as soon as I can find one
Old 04-20-2016, 02:28 PM
ev0lution7's Avatar
ev0lution7
ev0lution7 is offline
I am running the older Hayes 4pot caliper from a vrod and now converted to dual disk. Well worth the extra stopping power.
Quick Reply: front brake caliper? which one?
