heal on pipe???
RE: heel on pipe???
ORIGINAL: MacAttack
Oven cleaner seems to work pretty well. My wife's bike seems to pick these up, and the oven cleaner does a good job of removing them. Acetone might work well too.
Inquiring minds are.... inquiring.
RE: heel on pipe???
Supposedly warm the bike up and spray easy off oven cleaner on a towel. Wipe the hot pipe and the stuff stuck on the pipe will cme off. I would then repolish my pipes. I have not tried this but do not spray it directly on the bike as easy off will eat through the poweder coat on other parts of the bike. Good luck.
RE: heel on pipe???
I use the oven cleaner warm (and would use acetone cold). I let the cleaner sit for about 5 minutes, then wipe it off with a towel. You could use a piece of cardboard to prevent overspray. Easy-off worked fine for me.
Another trick I've heard of, but didn't have success with, was using a double-edged razor blade to scrape it off. Fortunately, my wife hasn't discovered the scratch mark![:@]
