Adding Apes to an '05 Roadster help re:brakes
Hey guys, so I found a similar topic but I'm hoping to hear from someone who has worked on my specific bike.
I want to put 12" apes on my 1200 Roadster(stock bars ATM) but am having trouble locating a cable kit that matches my bike due to the dual disc front brake. Has anyone else made this mod on an 04-06 Roadster? Did you find a kit that worked or have to build a brake kit yourself?
I initially used this kit: http://www.jpcycles.com/product/512-299 which the folks at JP cycles assured me was for dual disc, but when I brought it over to my mechanic he said it was not. Is the mechanic wrong or the parts people, I don't know! I've also emailed Burly to see if they have a solution for me.
Anyway, any help you guys can provide in the mean time is much appreciated.
Thanks
Thanks
The illustration is for a single brake line, which plainly won't work for your bike. The list of bikes the kit is said to fit includes single rotor models as well as twin rotor models. I suggest you contact JP, as what they sent you is not suitable. You need a set of three hoses plus a junction piece to bring them all together, which normally fits under the bottom tree.
This is not the correct kit for your bike, but it does show a set of three hoses.
Thanks for the info grbrown. I was recommended to purchase a Burly cables kit and a separate a DIY brake kit:
Does this seem appropriate? I ask because this recommendation comes from one of the people I've already heard conflicting reports from. Thanks again
Hmm, dunno why the hyperlink doesn't work but this is the link:
https://www.denniskirk.com/magnum-sh...rd/1906794.sku
I've looked at the ready made kits, but most of the dual disc ones don't list my bike as compatible, though I suppose it might just be because its less common..
yo_bear (04-16-2016)
