15 iron 883 front tire
03-31-2016, 07:45 PM
I'm losing about 4 pounds every day put air in it spray around everything no bubbles also check valve stem core. Any suggestions
03-31-2016, 08:49 PM
tube or tubeless? Spoked or mag type wheel?
03-31-2016, 08:51 PM
03-31-2016, 08:58 PM
You may not like it, but putting some soapy water into tire will stop slow leaks.
03-31-2016, 08:59 PM
Newer bike...when did you buy & what's the dealer say?
04-01-2016, 07:05 AM
Check the valve core is tight!
04-01-2016, 11:31 AM
Checked the core. Bought it June 2015 new. There booked 3 weeks out
04-01-2016, 05:02 PM
Spit on the end of the core, look for bubbles. Tight doesn't mean good.
04-01-2016, 05:05 PM
I will try that thank you
04-01-2016, 05:15 PM
Found it got dirt between tire n rim very little cause this
