96 Sportster Sport Speedometer Issue
Hey there! Been following posts from this group for 6 months and want to thank everyone for their insight. Recently picked up a 1996 XL1200S with 3501 miles, but actual is approximately 2k miles. Yes, actual miles! I say approximately because the speedo/odo is registering about twice (2x) the speed and mileage.
Through the help of the great peeps here on HDForums, I have been able to clean VSS and check the connections and put her back together and still get exactly "double" mileage and speed?
Stopped at (2) local HD shops and get the same'o same'o. The bike is too "obsolete" - "we have NO idea", "Call HD"???
Called HD America and they have "NO Suggestions"?
Anyone have any ideas or input that might help? Before I go buying an aftermarket speedo? I am absolutely "befuddled"!!
Thanks in advance!
Thanks in advance!
Thanks Von Zipper! Considered that possibility. However, it is exactly "double" (ie: 25=50, 55=110, etc.) Additionally, I have guaged with a GPS and if GPS shows .6 the odo shows 1.2, etc.
I asked HD America tech, maybe a key on/off while holding reset, with bike pointing north and uphill? They said "No such magic"?
Yessir, it is an electronic speedo. The sensor is in the rear of tranny. B!#ch to get to, but I removed it and it was remarkably clean. I did clean it and reinstalled, but same results. This evening I am going to pull bracket, disconnect, clean and inspect entire length of wiring to see if any "wear"? Next thought is to replace VSS and start over until I reach the speedo. Then if NO results? I guess replace speedo?
I am perplexed?? All indicators of a VSS bad are not there? Speedo works, odo works, self cancel turns work?
Frustrating as hell! Thanks for the support!
Howdy fellow Texan. Unfortunately without the 3 to 4 hundred dollar speedo checker, (HD-41354) You are left shotgun troubleshooting. As you have probably already figured out by now, there are only two parts that can be the issue. The speed sensor, which sends a square wave (Hz) signal to the speedo, or the speedo itself which in turn, interprets that data. Both of them are working, one not so good!
I know a sensor ain't a killer at about 60 bucks, but that dang speedo is a bear. That's why I went with my Dakota Digital. Where bout's you from?
Looks good Lonnie Mac. Has been on the back of my mind just to give in and do the aftermarket speedo. Pulled speedo and bracket this eve. Decided before I give up I am going to order a new Sensor and go for the "hail mary". I'm not too hopeful with that, but like you said, $60 is a cheap starting point.
By the way I'm just outside SATX. "God's Country"!!
