My Clutch Is Maladjusted. Did I Raise It Wrong?
My 2007 1200C's clutch will not stay adjusted.
It has 16k miles and I've adjusted it several times. When I properly readjust it (again) it gets out of adjustment by 2 FULL turns! It stays in gear, however, one issue is it very difficult to find neutral when at idle. Also the clutch seems to be slipping under heavy throttle and higher revs.
Do I need a new clutch pack? I don't want to buy that damn $80 compression tool that I'll likely use only once.
Any diagnosis would be appreciated. Thanks
Don't beat yourself up over your maladjusted clutch. There are no guarantees in life & you never know what's in the cards.
I'd say if you have a little play at the lever....oh hell, I've never had this issue with any of my clutches, so I can't give any useful advise. Unless it has been punished or abused over the years, it should not need to be replaced. I've had 3 Sportsters with more miles, and the clutches were fine. Suppose adjust it like the factory manual says and go from there.
Good luck fixing the problem.
