Fuel leaking, help?
Fuel leaking, help?
So I have fuel that is leaking from the bottom part of the engine, it looks as though it is stemming from an aftermarket fuel filter of some sort. I took it to Harley and the dude said he has never in his 20 years seen anything like it and wouldn't be comfortable fixing it. Anyone have any clue on how to fix this issue? I am attaching pictures as well. Its a 1994 sportster.
Fuel is leakimg from the little round thing in the middle.
You can see where the fuel is pooling up. That is from 4 or so hours of sitting.
Up close look.
Another look.
The amount of gas that leaked out overnight.
Up close look.
Another look.
The little round thing is a sediment bowl. You may find some help in this thread.
https://www.hdforums.com/forum/evo-c...owing-gas.html
Received 49,877 Likes
Your petcock should have a filter screen inside the tank. Why not just get some new fuel line and eliminate that bowl entirely. I've read that adding an inline filter actually hurts fuel flow. It is a gravity fed system, not pumped. FLush out your gas tank, take out the petcock and see if the screen is still intact.
John
John
boldt.timothyj
01-14-2018 09:33 AM
