Metal sheds
Old 10-10-2017 | 08:35 AM
John Harper's Avatar
John Harper
I had to store my bike in a metal shed for a while. Lots of condensation. I ended up getting a cover and leaving it outside whenever possible. Now I have a nice toasty garage.
John
Old 10-10-2017 | 11:55 AM
HOTLAP's Avatar
HOTLAP
You could try a solar powered vent like this:
Amazon Amazon
And/or a chemical moisture absorber like this:
Amazon Amazon
Old 10-10-2017 | 12:09 PM
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by maxthedoggy
Hi Guys
I store my 883 in a large steel shed in my garden, I found that when it's very humid outside or if it's very wet outside my bike will have a very thin covering of moisture over it.
The shed does not leak, I'm guessing the bike 'sweating is due to the metal shed, I've never had any problems with my bikes in wooden sheds in the past,I've found if I leave the heater on the bikes great.
Do I need more ventalation in there or I've even thought about buying a de-humidifer (sp!).....not sure how these things work or more importantly how much they would cost to run all the time........advice anyone?
Cheers
Mark
Get some 2" batt insulation with a vapor seal back and some spray contact glue. Cover all of the walls and ceiling with the insulation. You won`t have condensation after that. You can buy a roll of that insulation that won`t be too expensive. It wouldn`t be a bad idea to add a turbine roof vent as well, plus install louvers in the door approx. the same area as the turbine vent.
Old 10-10-2017 | 12:13 PM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by Thumper26
Coolness in the evening/night will form condensation on and in metal sheds because of metal's non-insulating quality. Wooden sheds absorb the condensation and keep what's in them relatively free of condensation. A dehumidifier is NOT adequate. Only heat will adequately help prevent the moisture from forming in a metal shed. An absorbent bike cover may help...
You don't want anything "absorbent" ...
Old 10-10-2017 | 12:17 PM
Uncle Larry
The moisture thing is a very common problem in the northern climate ... Do not cover the scooter with anything that doesn't breathe ... It will trap the moisture under the cover and on the scooter and make a real mess out of it ... This happens every year to me ( for the last 50 or so ) ... I have had it happen in storage sheds, garages and attached garages ... the moisture will evaporate relatively quickly and hasn't caused any problems for me.
TOMMYBLAZIN
General Topics/Tech Tips
15
01-28-2017 01:30 PM
Fogle
03-24-2011 11:50 PM
warrenrl
10-31-2010 10:51 PM
pop1
01-10-2008 04:10 PM
YellowHawk
12-20-2007 11:08 PM
Quick Reply: Metal sheds
