More brake lighting!
Ordered the HD wiring kit that converts the two rear turn signals to 'running' and 'brake lights' while still working as turn signals for my 2009 1200L. Now I've been told I might need to increase the brake circuit wire size and fuse to carry the increased load.
Wouldn't HD mention that in the ordering process if it were going to be necessary? That definitely takes it out of the 'Plug-n-Play' category if true.
Oh well, anyone here know for sure. I can see a slight load increase in running and brake light circuit, but WOW, really enough to cause wiring and fuse issues?
Thanks and regards, Joe.
PS: The kit includes the required 'snap on' red lenses to replace the amber ones on the turn signal lights.
I modified my saddlebag 2-wire single element LED lights to DK Customs RBT module and did not need a load equalizer, but I retained my stock rear turn signal.
I am planning to install an engine guard running light and asked DK Customs if I needed to run a load equalizer. This is the response.
Suggest you inquire with DK Customs if you need one...they will have whatever you need including a load equalizer if need. But IMO based on the instructions, if you still have your front turn signals, a load equalizer is not needed.
- If you have a 2014 or later, you do NOT need a load equalizer.
- If you have a 2013 or earlier, & are running the stock rear turn signals, you do Not need a load equalizer.
- If you have a 2013 or earlier, & you're running LED rear turn signals, but keep the stock front turn signals, you do NOT need a load equalizer.
- The Only time you need a load equalizer is if you have a 2013 or earlier, And have LED turn signals up front and in back, and do not keep any of the stock turn signals, then you will need a load equalizer.
- https://www.hdforums.com/forum/sport...79-led-h4.html
- https://www.hdforums.com/forum/dyna-...n-signals.html
i lowered my current draw via LED, my front turn signals are as bright as running lights, my rears are now run/brake/turn (cd triple play), and my rears are easily way brighter than stock. all plug-n-play
i'd ditch/return the ordered part... and call Shilo @ Ridethelite.com 754-367-5596
Thanks to all. I was hoping it was a simple 'P-n-P' since I wasn't intending to replace anything with LED's at the moment. Maybe in the future, but for right now I just wanted to gain all the 'brake' lighting available.
Dang, I see so many folks coming up to traffic lights, etc with their heads stuck looking down at their damned smart phones and not paying attention. I figured an extra brake light or two might not be a bad thing.
Regards, Joe.
Regards, Joe.
Regards, Joe.
Regards, Joe.
I presume you're talking about the 69463-06B auxiliary run/turn/brake kit? Plug it in, change out the rear lenses, and go riding; you'll be just fine. I've installed that kit on several Sportsters... no worries
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
Regards, Joe.
Regards, Joe.
ride safe
