Baffles...
Old 01-12-2016 | 08:45 AM
grbrown's Avatar
grbrown
Old 01-19-2016 | 07:44 PM
sawka's Avatar
sawka
I thought I would follow up on this since I figured out a solution WITHOUT buying a whole new exhaust system. I thought about it on a plane ride hole as was mentioned earlier about cutting the baffles. I thought about fluid mechanics and how it would work and came with this concept which Im sure is nothing new to the motorcycle industry. Since the air flows through the center and is forced outward I cut the baffles and turned it around so the air would go to the outside and be forced inward making it a bit more free flowing although not a muffled. This just required a drill for a new screw hole and a hack saw.
I made them 5 inches overall so I could cut them down as necessary. Then reinserted and reinstalled the TTI's
Once I got out I realized that although it was not as quiet as before it was a great sound now a bit less of the power I had straight piped with the tti's. This is worth mentioning again this isnt the best but it is rather cheap. I had no intention of gaining more power by doing this mod I simply wanted it a bit quiter without LOSING all power. Im sure Ill be reminded again that 2 into 1's are better and that is great but This is a way t make due with a look you like. I have a video of the sound but i need to pack for another trip so if somebody really cares I can add it when I get back. There is a tiny hiccup when i first give it the throttle but it wasnt noticeably when I took it out and I still had all the low end I could have hopped for with drag pipes. I hope this fix helps anyone with a similar issue.
Old 01-19-2016 | 10:23 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Put your TTI's back in with those cut down baffles and you will gain back more torque and will also lower the tone some. btw, W version of the TTI's make a more pleasant tone (for most) and definitely create more power.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Old 01-19-2016 | 10:39 PM
sawka's Avatar
sawka
I did put the TTI's back in without hesitation. If i didnt The low end power would just not be there. Great product by the way. I specifically used the q version simply to keep noise down a bit and I am still extremely satisfied with the torque I got back.
Old 01-20-2016 | 11:11 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Cool deal!
daBreeze
04-22-2011 12:00 AM
FLSTF
Exhaust System Topics
03-10-2009 11:24 AM
eyefrgt
08-26-2008 11:43 AM
markymark02
06-09-2008 03:00 PM
heavy hauler
04-25-2006 01:26 AM
Quick Reply: Baffles...
