Abs?
Abs?
Anyone opt for ABS on their new Sporty? I've had them on BMW's before, and would not buy a new bike without them, but I'd like to hear input from new Sporty owners that have them.
Is it an integrated system, whereby if you activate by either peddle or grip both front and back operate?
What's your take on single disk ABS in the front, any issues?
Thanks,
Thanks,
If the system is as on the Touring models, there is a single ABS unit, into which front and rear brakes are linked, so I would call it an integrated system. I don't see any difference in single or dual discs, as far as ABS is concerned.
I've ridden over 50k miles on a BMW with ABS and wouldn't personally pay extra to add it. Many of us won't apply the brakes hard enough to activate it.
Ive read the hysterics for this and if you want it go for it, I've also read how genuinely hard it is to keep these working well on a bike, a bit of rust and they fail so you paid a bunch of cash for standard brakes, to fix them after failure is not hard but costly.
My advice is to read-up on the different forums, the pros & cons, look at how simple or complicated they are to repair / upkeep etc, and YOU DECIDE, dont listen to all the bubble-hype you will get from this post, educate and emancipate yourself from the dealers.
Cheers to all,
Fire at will . . .
Cheers to all,
Fire at will . . .
ABS is the only significant improvement to newer model Sportsters. I don't have it on my 2011 48 because it was not offered then. I strongly recommend it. My next bike, if ever I buy another, will have ABS.
Having that said, keep in mind that ABS works only when you are going upright and in a straight line, period.
I have it on my 11 roadking and it has worked well with no issues and
helped me out of a few hairy issues where I came around a corner at speed
only to find the traffic stopped ahead all the while going down hill in heavy traffic..
(I deal with washington DC beltway traffic every day, if you live here you will understand what that means)....
While a roadking and sportster are quite different I can see where you I could benefit
from having ABS on a sportster, so I would recommend them...
