Custom Dynamics TruWrapz on '14 sporty, load equalizer?
I asked 2 different sellers if I would need a load equalizer on my '14 sporty to run these turn signals. One said yes, the other said no. I have an email in to the company but no response as of yet. I guess there are also two different types, one does running lights and then switches to turn signals when activated, the other does just turn signals?
Does anyone know by chance if I do need one? I'm confused now.
Kyle: Are you using them as running lights or turn signals?
Dane: turn signals
Kyle: Ok, yes yo uwill need a load equalizer.
Dane: turn signals
Since your Sportster is equipped with a CANBUS electrical system, you will not need a load equalizer in order for the Custom Dynamics TruWrapz 360-Degree LED Fork Lights For Harley to function appropriately.
Received 2,201 Likes
sportster needed it, but it's an 2007... not as complicated. i'd just get signals and worry about it later. in most non-canbus cases, the LE is only needed if you go front and back anyway. plenty get away with just the front or back and no LE
I have a 2013. When i called them, they said it varies and I would just have to install it and see if it worked without a load equalizer or not.
Received 4,221 Likes
Can't tell you about the Custom Dynamics, it requires you do do some wiring, so possibly both answers you received are correct...ie: how you do your wiring may, or may not need a load equalizer.
We have a Plug-n-Play unit for your bike that does NOT require a load equalizer.
Just put the lights on, and plug it into the Harley connectors and ride!
You can see it HERE
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
Fathertime500
01-21-2013 04:34 AM
