A/C - crankcase breather
If you mean that it will route the oil mist back to the oil tank then no I know of nothing that does that.
Your only choices are to route the oil mist back into the combustion chamber (as per factory spec) or to vent it to the atmosphere either directly or thru a filter, I would recommend the later where it is vented rather than routed back to the combustion chamber.
Received 2,201 Likes
people have tons of variations:
https://www.hdforums.com/forum/dyna-...ing-plate.html
Looks like a solution in search of a problem to me. BTW, I have a 1991, so virtually identical to OP's bike. I've got the SE aircleaner, and my carb is spotless after 25 years, not sure what the big worry is about.
John
How much oil could possibly vent out between oil changes? I've never needed to add oil between service intervals. If your umbrella valves are working, their should be minimal/no mess at all.
John
John
i've been looking over people's designs. there are quite a few in these forums.
my hold up is i'm looking for a clear catch so i can see what's coming out before venting.
i don't really know to tell the truth. i'm getting ready to add a breather setup to both my bikes after seeing this in my sportster's combustion chambers:
Sportster 883/1200 endoscope front and rear cylinders - YouTube
