7 in headlight
Here is a thread asking the same question....there are some options
https://www.hdforums.com/forum/sport...ase-share.html
I went with this one using DK Customs relocation kit.
http://www.jpcycles.com/product/3100...&totalResult=1
http://dkcustomproducts.com/Modular-...HL-BRK-MOD.htm
If you have a lower tree mount you can use any of the bottom mount 7" I believe. Most people get one from a fat boy or other.
If you're a stock visor mount you can just get a side mounted 7" or you can drill the lower tree and go with a bottom mount one.
I did side mount, and I plan to eventually drill the tree and change to a bottom mount one so that I'm not attached to the forks, then use the side mounted headlight for another bike. The fork mounted headlight is annoying when doing fork work.
drumer66
02-21-2008 08:17 PM
