Best 2 into 1 exhaust for Iron 883
So I suppose depending on the application of the exhaust it seems that the 2 into 1 exhaust provide the best power in a wide range. I'm doing a lot of street riding and like taking long rides. By no means with intentions of racing etc. Just want the most "fun" out of an exhaust. Loud, fast and fun.
Any one have specific experience with any 2 into 1 exhaust?
Ive seen on one of the forums how some of these exhausts stacked up on the dyno. Noticed that the Two Brothers 2 into 1 did better than the Roland Sands.
Thoughts?
They also mentioned about a ground clearance issue with the TBR exhaust system while taking turns.
Opinions on the Vance and Hines 2 into 1 comp series?
Right now I'm leaning towards the TBR 2 into 1.
Thoughts?
Patriot Defender is the reigning champ of sportster exhausts
http://www.hammerperf.com/ttxlexhaust.shtml#tbcomps
http://patriotpipes.com/
Received 2,199 Likes
Received 4,197 Likes
Thoughts?
Thoughts?
However, you want loud, fast and fun, not racing...so you probably won't be able to tell the difference between them.
Some fun might be building (or sketching out and having someone else weld up) your own 2-1 pipe. Below is what I did with an Exhaust Builders Kit for my Sportster.
Another option is to modify your own exhaust you have right now. You can get a great sound and performance out of them with very little $ and a little work.
I think you will be pleasantly surprised at the classic Harley sound, and also with the significant increase in power.
Here are a couple of vids on how, and what the results look and sound like...if you still want 2-1 after that, you are not out much $ at all.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
http://www.dkcustomproducts.com/NRHS...?productId=264
$699+ crap slip-ons/modded stockers w/thunder torque inserts $27+ highflo a/c (?, more air... however you get it)= better bet. then worry about silly pipes to impress people you don't even know.
* relatively
not being a hobby/fun hater. just being honest. you will not see any monster gains from going 2-1 on an 883, you can see this echo'd in the comments above. get a basic noise set until you boost the power. a sub-$300 set or 2-1 will do you fine... or maybe slip-ons or some cliche vance and hines crap
