Tire Recommendation
Tire Recommendation
Just went out to ride my bike and my rear tire was flat. There is a fairly large puncture with a piece of nail sticking out of it. When I called the dealer they said the tire was not under warranty since I didn't buy the extended warranty. I looked up the brochure from Dunlop and it says they don't cover punctures.
Anyway, the dealer said it would cost me $220 to replace the tire with the same one. Is that the best way to go, or should I get a different brand/type?
Thanks,
Barry
Thanks,
Barry
RE: Tire Recommendation
I'm about to replace my tires with metzlers. From what I have been told they are a little bit better tire and should last just as long if not longer. A lot of folks are split down the middle on the issue but with the price being very similar I figure I would try the metzlers this time and if I'm unhappy I can always go back to the standard dunlops.
Hope this helps.
Hope this helps.
"Ride-On" is a tire sealant you put in your tires BEFORE a flat. Easy to put in, and puncture flats are a thing of the past. Here's a link:
http://www.ride-onshop.com/
I bought some chen shin streetshark tires on e-bay . Paid $100.00 for the set. They are very graby and seem to handle steel bridges and asphalt drizzle better than the dunlop tires. They corner very well. I have done 10,000 K on them so far and they still have at least 2/3 or thetread left .. Mark..
I was happy with the Dunlop tires, but due to the strike, couldn't get the rear tire. Went with Metzelers. So far, I LOVE them. but too early too give a good report. Only about 1,000 miles on them.
One thing to consider, if you change tire brands (designs) it's normally a good idea to replace both tires.
Another thing to consider:
DON'T SHOP FOR TIRES AT THE HARLEY DEALERSHIP!!!!!!!! IF YOU NEED TIRES FOR YOUR CHEVY, DO YOU BUY THEM AT THE CHEVY DEALERSHIP??????
Just think about it....
