Cvaria's 2007 883 Standard (XLCN): Consolidated Thread of Nonsense (Working)
#861
Received 2,201 Likes
but, what i think i hear you saying is cover/hide them. Yes sir. Will do.
#862
#863
im happy. One project down.
Been eyeing up the roadster frontend.. brake mount are holding me up. May go with ODC roma frontend instead. Teally dont want to give up my ness
#864
good and bad...
cover came:
cleans up good.... but, i was being a bonehead and didn't notice that i wired the switch wrong. the lights come on when switched to the acc pole. didn't click til i started it up and there was no tach. derp derp
remedials: https://www.hdforums.com/forum/sport...l#post14990538
Edit:
when i swapped the wires. i put them on in reverse. disaster averted.
put them back in the right order.... fixed.
cover came:
Edit:
- ign= everything on
- off=off
- acc=position marker, accessory power only, brake light
deadrubberboy (10-24-2017)
#865
2018 Street bob/softail bucket confirmed
Looks like it is just the street bob and low rider bucket
p/n: 67700455
Looks like it is the same as the diagram above but, there is an adapter included to adapt the softail headlight to front main harness lead to the older style 4 pin terminal connection.
adapter:
p/n: 67700455
The headlight bucket is totally new and also has a new terminal connection inside. There is no more h4 and the lamp also bolts in. So folks will need adapters and a new bucket if you want to use anything other than the hd "signature" daymaker... Right now anyway.
http://shop.outpostalaska.com/oempar...p_-_fxbb,_fxlr
adapter:
#866
i am not installing the bucket or the led. honestly the new daymaker is weak compared to aftermarker options in the same range for the near $600 you'd spend on all this stuff, it'd be better to get a $50 wisamic or other faker, a DK LED H4, a $375 trubeam/vortex/8690m, or drop large money on an 8690a.
the only real value in the signature daymaker or the 8620(terrible), is the look of the units. i don't get caught up in looks so more power to those that care about that stuff. the signature looks good. probably one of the best looking i've ever seen but, i'd rather see and avoid danger. i will consolidate all this into a separate led thread.
slvrscoobie (10-22-2017)
#867
i like these... need to build the baalls to paint my tank solid red
http://shop.outpostalaska.com/OEMpar...18)//FUEL_TANK
slvrscoobie (10-24-2017)
#868
@slvrscoobie :
How are your 3d printed goods holding up to water and heat? painted any of that stuff? that may be the alternative to getting this done.
boardtracker response:
They are VIN restricted and there is no way someone with a brand new CVO has already lost their medallion.
BoardtrackerHarleyOnline.com | Return Policy
On 10/24/2017 9:59 AM, Web User wrote:
so... what are you saying? brick and mortar only?
From: BoardtrackerHarleyOnline <support@boardtrackerharleyonline.com>
Sent: Tuesday, October 24, 2017 10:09 AM
Subject: Re: Contact Form Notification
Hi,
We do not sell those items online.
Hi,
slvrscoobie (10-25-2017)
#869
Lame. With all the talk of their #'s being down, and what must be a crazy mark up on the parts I can't believe they wouldn't sell them.
cvaria (10-24-2017)
