Cvaria's 2007 883 Standard (XLCN): Consolidated Thread of Nonsense (Working)
#581
#582
Received 2,199 Likes
engine crew thinks in lean based on the plugs. That may be part of the heat issue. Good learning experience. Im happy
#583
#584
I also don't know what I'm doing......
That being said, my memory of my break in period, was running much hotter for several hundred miles.
Maybe she will settle down after a bit? Can you adjust your map to run richer across the board for break in?
Again, I don't know what I'm doing....
#586
Has to be something dragging.... scored a nice 441 degrees
i'm going to go through the calipers one by one, if there's nothing there... maybe those new hd bearings are causing problems...
no idea what's happening
i tried enriching and it didn't make a difference heat wise, just a lot of bogging the engine down.
#587
#588
after a bit of time, your AFR is locked at 14.6 no matter what kpa is.
I would think with higher loads you'd want to switch out of that & go a
bit richer, but what do I know....
good luck,
T.
cvaria (05-09-2017)
#590
jeez....
mine is out in space.... can you pull and post a copy of yours. change ".pvt" to ".txt" i need to look through and see what else is different.
glad i'm taking this beating now rather than on the dyna, that thing would explode with this kinda heat. just looked at the tune dynojet sent and it is just almost the same as above
