Cvaria's 2007 883 Standard (XLCN): Consolidated Thread of Nonsense (Working)
#121
both. Anti-rivet rickets and better performance over stock clutch when beefing output.
ease? I don't think it will be hard at all. More fun than difficult. I've gone into my dyna primary already and made it out alive.
I actually cant wait to begin the job of changing the clutch. I want to take inventory of the various parts and how they work. (Sorry for the over written sentences, had to phrase it so it did sound/read the wrong way)
waiting on assembly lube(cam) and dino gear oil as T pointed out earlier.
i think the dark custom era is over to so i need to find a new derby in gloss black. Air cleaner trim too
IMHO, the clutch is fairly easy. Just be sure to have all your parts ready
(gaskets/clutch/tools/fluid)
On the cam, I assume by '585' you mean the Screamin' Eagle 585.
Here's what's on the HD website:
Requires installation of Performance Cylinder Heads P/N 16500074 or 16500347, or upgrade of Original Equipment heads with Performance Valve Spring Kit P/N 18013-03A
I know you said you didn't want to have to change springs, but it sounds
like the 585 cam requires it.
hth,
T.
#122
Received 2,199 Likes
At this rate, i'll have scope crept out to huge pile of parts in a few weeks. I mentioned the springs up above with the chrome rocker boxes, and rear sets.
#123
yeah, i've aready started to factor them in since i'll be pulling the rocker boxes. Might be worth going with the ported heads. But, 700 for the heads, 300 for cams, ~50 for gaskets... might just need to look at the 07-13 stage IV - p/n: 92500029. I think the 585s / evil pro are in there.
For $2,083.56 I think you can do better with Hammer Perf. parts
(ported heads, 30deg 1250 pistons, new jugs, cam etc) I dont think
you need the 'tuner' in the kit above nor the 58mm throttle body/manifold.
But to each his/her own...
good luck,
T.
#124
Just an opinion: Wow, just looked up that p/n at NewCastleHD.
good luck,
T.
good luck,
T.
#125
Eer mah gerd!!!
I had doubts but, i'm okay with it right now...will have to see it without "garage" goggles.
wasn't sure
felt better after seeing first wheel/side done
finished and dropped it down to oggle it. no flash
flash
led+flash.... them lizard lights are tired and need to be replaced with brighter lights...
see what i mean
light from big bro + flash
light from big bro + no flash
can't knock it. if some one t-bones me, they wanted to... no way they didn't see me.
#126
#127
#129
#130
