Does the Harley Stage 1 air cleaner need a fuel management tuner?
Received 2,201 Likes
Power Vision is a great product. $449(+330 for the auto tune pro) verses $179.
I'll stick to the $179 and save the $600 for my big bike, guns, or cars.
2013 HARLEY-DAVIDSON SPORTSTER 1200 SEVENTY-TWO XL 1200V
Change Vehicle
Your Options
Color: Black
Discounted Accessory: $330 - Add Auto Tune Pro AT-110
Change Vehicle Options
Product Information
Was: $970.90
Price: $ 779.00
Item #: PV-1B_AT-110
Quantity:
Change Vehicle
Your Options
Color: Black
Product Information
Was: $970.90
Price: $ 779.00
Quantity:
I fought it for a while, but after auto tuning with the PV on my sportster, it performs better than it did with the $150 stage 1 from hd. way better. on the dyna, it got rid of the peterbilt feel and gave me a raw torque monster... i was b***hing about how much i hated the dyna, then the PV happened. totally different bike.
i paid $429:
http://www.ebay.com/itm/251994652639...%3AMEBIDX%3AIT
way more useful than cutting corners on a Micro EFI Tuner. I'm no pro, not by a longshot. but i wouldn't waste 179 like that. you be better off paying 250-300 for an actual dyno at the dealer.
to each his own.
The Vance & Hines Fuel Pak 3 that bluetooth connects to your smartphone or laptop seems pretty awesome. It's as low as $300 on ebay.
Bike definitely accelerates faster than my 650cc V Star! I got the bike late Friday night. I haven't had much time riding it yet. I actual spent Saturday doing the one day MSF experienced rider course at community college, but I took the V Star cause I didn't want to risk dropping the bike I just got.
https://www.hdforums.com/forum/ignit...-injection-55/
If you are running a high flow filter and full exhaust you should get it tuned in some way. You can go the HD route and have it dyno tuned which was worth the money in my opinion. Most dealers are running winter specials. My local dealer is $610 with the tuner and 3 hours of dyno work for the bike. I suggest it, just because the bike seems likes its running correct the air fuel ratio's are most likely off. Without it being properly tuned the bike will run rich to compensate from the increased air flow through the intake. Just my 2 cents...
Location: In the foothills of southwestern NC - US of A
In regards to aftermarket exhaust and intake, the rule of thumb is, that if you replace only one of either, a bottleneck will still exist that won't require a dyno, tuner, or Xied's (or rejet if carb'd) to correct, but if you replace both with "free flowing" characteristics, then the aformentioned are highly recommended to counteract this increased lean condition and give your ECM (or carb) the ability to afford your engine its proper/correct A/F ratio, its best performance, to smoothen acceleration, and to help reduce or sometimes eliminate decel popping issues.
=8^)
