Tires for the 48
Tires for the 48
Got 10,000 miles on the sportster 48 and need some new treads. The stock dunlops are a bit hard and don't grip well when it is damp or foggy out. We have a lot of steep hills and I've slid to a stop going down hill and spun my tire trying to go uphill in town. I ride year round unless it is below freezing or rainy. I want a softer compound tire that grips well. Looking for one of the classic or retro tires from coker, shinko or Avon. I don't know what makes a tire grip better the tread or the rubber compound. Also, I noticed most of the tires I've looked at online are bias ply. I thought tires were steel belted radials now a days. I'm not dragging pipes and pegs when I go around corners although I like to get on the throttle sometimes. Just looking for a good tire. It's hard to find a place that has a large selection of motorcycle tires in stock to look at and feel the rubber. Any suggestions would be appreciated.
Shinko 777's are the best tire I've ever ran in the rain. Very god traction on wet or dry, very sticky so they did wear somewhat quick after I killed a rear in 4500mi on a honda shadow 750.
I've also found ANY motorcycle tire will spin on wet pavement if you goose it, so it all about throttle and clutch control to prevent that.
I was hoping this tire would work for me, too, but I learned it doesn't fit a '14 48.
Thanks guys for the input. I definitely need to go with the softer compound with out regard to tire life. We have some steep hills here. Not as bad as San Francisco but bad enough. Part of the problem is it's hard to find a place that stocks them. I will try one of the above mentioned tires. I guess I will order from JP Cycles unless someone has a better idea.
