NRHS 1250 kit
#31
Received 2,201 Likes
Justin, Harley sell more than one kit! They have a 1200 conversion, which replaces every 883 part, including heads, to convert an 883 to a stock 1200. They also have an SE 1200 kit to convert an 883, using the stock 883 heads, which comes with higher CR pistons, cams and tuner and is designed to give significantly higher performance than a stock 1200.
#32
"SCREAMIN’ EAGLE PRO SPORTSTER® 883CC TO
1200CC STAGE II CONVERSION KIT
Upgrade displacement and performance of your track-dedicated
Iron 883™ model. The all-black big bore cylinders
bump your engine’s displacement to 1200cc, and the matching
10:1 high-compression pistons are engineered to maximize
the performance with the Original Equipment cylinder
heads. The high performance Screamin’ Eagle® cams (#25197-
04) are designed to complement the stock lifters, valve
springs and rocker arms. Complete kit includes top-end
gaskets, performance clutch spring, and the Screamin’ Eagle
Pro Super Tuner for track-side performance adjustments."
#33
Here ya go! #29836-10.
OldBoldPilot
02-07-2011 03:44 PM
