Oops! Dropped something in the gas tank...
Old 11-15-2015, 04:08 PM
3bc's Avatar
3bc
3bc is offline
Default Oops! Dropped something in the gas tank...
I was winterizing the bike this afternoon and accidentally knocked something in my gas tank. I had to buy a new bottle of sea foam and inside the cap is a little pull tab like you would find in your 1/2 gallon carton of milk/OJ, what have you. Set that on the tank to throw away after a minute and accidentally knocked it right into the tank. How concerened should I be? Not knowing what I don't know, I'm inclined to think it won't pose any serious problems, but hopefully someone who knows what they are talking about can confirm as much!
Old 11-15-2015, 04:57 PM
cHarley's Avatar
cHarley
cHarley is offline
I would want to get it out of the tank.
Unfortunately, you didn't tell us anything about your bike (like the model YEAR), so I have no idea whether it's a carb bike with a petcock, or EFI with a fuel pump.
Old 11-15-2015, 06:43 PM
3bc's Avatar
3bc
3bc is offline
'14 48. Efi.
Old 11-15-2015, 06:57 PM
WVDevil's Avatar
WVDevil
WVDevil is offline
never mind; misread
Old 11-15-2015, 07:16 PM
Duracell's Avatar
Duracell
Duracell is offline
Received 1,656 Likes on 581 Posts
Four bolts, one connector and the quick disconnect. One beer. pull the tank and remove the foreign object.
Old 11-15-2015, 07:17 PM
Troops141's Avatar
Troops141
Troops141 is offline
I'd take the tank off and pull the pump from the bottom of the tank, that'll open up a large hole in the bottom of your tank that you'll be able to get it out.
Old 11-15-2015, 07:19 PM
RANGER73's Avatar
RANGER73
RANGER73 is online now
Received 6,099 Likes on 3,104 Posts
I would try very hard to get it out. It's going to take some lifting, shaking and tilting if you don't remove the tank.
Old 11-15-2015, 07:31 PM
Duracell's Avatar
Duracell
Duracell is offline
Did I miss something? Is the OP really large and green? Lifting shaking and tilting a sportster sounds kinda difficult. I'd just pull the tank
Old 11-15-2015, 07:35 PM
RANGER73's Avatar
RANGER73
Won't explain the dynamics, but if you lock the forks and jack the rear. secure it, and shake like hell, you could get it to move forward under the bung hole. And possibly snag it.
Old 11-15-2015, 08:19 PM
Guzzi's Avatar
Guzzi
Guzzi is offline
Have you tried using mechanical fingers?
Quick Reply: Oops! Dropped something in the gas tank...
