Been Sitting Around
I'd change the oil & primary oil to start with. The carb might be varnish-like, or have dried/damaged rubber components. Considering its age and lack of miles, I'd just rebuild it.
Before riding it:
I'd change the brake fluid and make sure the master cylinders are in good order. The calipers should be checked to make sure they aren't binding. Check the date codes on the tires, if they are older than 5 years then dry rot is possible. Check all critical fasteners for proper torque before riding.
Those are the immediate things that I'd start with. I'd just make a project out of going over the entire bike from top to bottom. Sounds fun!
Any pics?
Before riding it:
Any pics?
Before riding it:
Any pics?
Before riding it:
Any pics?
Having left the oil for a while turn the engine over with the plugs out, to lubricate the cylinders. That will also provide a better seal when starting the engine once the plugs are back in. Once running treat it as if it is new and run it in. Take care to ensure that the brakes function properly before whizzing off down the road......
Yup! The other brands cover a wide range of years and models and not very well, so best avoided, unless you get one to compliment a factory one. You may get lucky and find a secondhand one in the HDF classifieds or Ebay, otherwise any dealer can supply, even if they don't have one in stock. You'll get your money back the first time you use it, so they are actually very cheap!!!!
