riding lights too high to put windshield on
Tried to put quick-release windshield on my Sportster for the first time today.
Bottom edge of windshield hits the riding lights before the brackets meet.
XL883C, 2005
If I move the riding light bar brackets down to below the crosspiece between the forks or will they be in the way of full fork travel? Seems to me impossible for fork movement that high.
see photo
Thanks
XL883C, 2005
see photo
Thanks
Check out this thread...all you need to know about relocating the turn signal to the lower triple tree
https://www.hdforums.com/forum/sport...ion-kit-5.html
Update: Sorry, disregard. Misread/misinterpreted your issue.
Looks simple enough to me! Those brackets will rotate on the fork legs? So slacken the clamping screws and swing them forwards so that you can install your windshield, then move them backwards and realign your lamps so that they clear your shield. I have the qd shield, but not those lamps, so I can imagine there won't be space to easily fit or remove yours, however it little juggling should work.
Having the lights shine through the windshield may not be best. Harley sells a WS for your application. That WS has semi-circle cut-outs at the bottom. Tape up the WS and cut it with a jig saw (saber saw), using a fine-toothed blade and a slow strokes-per-minute. Going too fast, melts the WS behind the blade and makes it messy. You can tape the foot of the jig saw, too. The cut edges can be cleaned up with sandpaper (drum sander) and a buffing wheel.
Windshield with auxiliary lighting:
http://www.harley-davidson.com/store...-20-5771601--1
Carl '69
06-26-2016 08:20 PM
