out of ideas
Old 10-24-2015, 07:33 PM
hellidontno's Avatar
hellidontno
hellidontno is offline
Stage III
Default out of ideas
I have a 1986 1100 sportster that runs but backfires bad, any body have any ideas where to start it acts like ignition problem. thanks
Old 10-25-2015, 04:01 AM
JustOneDean's Avatar
JustOneDean
JustOneDean is offline
For starters, does it do that all the time when it runs? Just idle? WOT? Hot/cold? Enrichener on/off? Have you checked the plugs, cleaned the carb? Just off the top of my head.
Old 10-25-2015, 09:13 AM
JimmyL's Avatar
JimmyL
JimmyL is offline
Mine will backfire a little on de-acceleration before it's warmed up. It seems to do it more if I push the choke in too soon, which leads me to believe a lean mixture causes the popping. You might want to check for a vacuum leak, or check into the carb jet sizes.
Old 10-25-2015, 04:27 PM
JustOneDean
Jimmy reminded me, decel pop isn't necessarily a bad thing. Best way to tell if the carb's jetted right is reading the spark plugs.
Old 10-25-2015, 07:19 PM
Iarecobra's Avatar
Iarecobra
Iarecobra is offline
Old 10-26-2015, 12:53 PM
hscic's Avatar
hscic
hscic is offline
In addition to the above, check for exhaust leaks.
Herbiewan
EVO
06-13-2024 08:47 AM
Kakha Barnovi
01-12-2019 05:14 PM
rstrydio
03-22-2014 07:02 PM
bluharley
EVO
07-16-2013 07:55 PM
DeputyDog605
Exhaust System Topics
04-25-2007 08:04 PM
Quick Reply: out of ideas
