A Little Too Loud
A Little Too Loud
What's up fellas.....I've had my Sporty a few weeks and I am in love with this bike - I've put about 1500 miles on her and I'm having a blast doing it.
Only 2 things I want to improve:
1) It's got a flat spot at low/mid RPM...gotta sort that out. I'm guessing the original owner added the pipes but didn't re-jet, so I'll dig in and do that to try to sort this out.
2) This thing SCREAMS hahaha....I love the sound of a tuned bike, but this thing is a little too loud. I have V&H Straight Shots with the factory baffles, and I ordered the quiet baffles yesterday; unfortunately I saw a post earlier today where I can wrap the stock baffle with a stove door gasket to help quiet it down (wish I'd thought of that earlier). Sucks that I spent $70 on baffles already, but I'm going to try both and see which sounds better. Worst case i'll send the baffles back and eat a restock fee.
My question is: I've heard the thunderheader is the best for performance, anyone have any suggestions for a moderate-volume performance exhaust? I live in a townhouse so I wanna keep the volume reasonable...pissing off the neighbors is never a good thing, I ride a lot so I don't want them crying to the HOA.
Received 4,225 Likes
The TTI's will definitely get rid of the flat spot...it is probably not tuning, just the nature of those pipes. The TTI's will give a good bump in low & mid range power.
The Thunder Header is a good pipe, and with a TTI in it will deepen the tone a bit and add about 5% to the low/mid range power. Same with the Patriot Defender. Neither one of them is a particularly quiet pipe.
Another good option for looks, performance and sound is the Competition Series 2-1. It is available in Stainless and Black. See Details HERE.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
Nice thank you!! I put the quiet baffles in Saturday and it's more neighborhood friendly - so I'm cool with these now.
BUT
Twice the bike started surging at highway speeds. Mid-throttle, just cruising around 70mph I felt a slight little surge/miss. I'm going to tackle cleaning the carb, intake seals and checking to see if its jetted pretty soon when the weather really cools down.
BUT
BUT
BUT
my baffles also fit flush w/ the end of the actual pipe, so I'd just have to drill thru the pipe and the baffle - which leads me to another problem, my heat shield doesn't have room. would I have to go thru all 3?
Last edited by HoganLongfellow; 10-26-2015 at 12:37 PM. Reason: typing too fast haha
Try the TTI's Q model using your existing baffles. It may be enough to quiet down your pipes and smooth out the flat spots while giving you more low-mid range power. If it works, return the quite baffles and save some money. Edit - just noticed you already installed the quiet baffles so I guess you need to work with it.
I used the W model and it also quiet down my pipes some so the Q model may be sufficient. TTI's are a low-cost high-benefit fix.
