Rear turn signals on a bobber
you should be able to mount some bullet LEDs in the existing holes in your struts. then run the wire behind the strut up to your rear harness.
http://www.ebay.com/itm/Mini-Bullet-...VVw1FM&vxp=mtr
americanworkmule (09-05-2016)
Bullet lights mounted on the struts should work as mentioned. Now being that you will need the to ride on a military base, you should get DOT approved signals only. Knowing how strict they are with the rules you should consider that. At most bases even the helmet needs to be DOT and or SNELL approved.
