Largest Rear Tire
Old 01-20-2005 | 02:16 AM
jtwax's Avatar
jtwax
2nd Gear
Default Largest Rear Tire
Can a guy put a 150 rear tire on a 98 sporty without hitting the belt guard? I can fudge the fender one way or the other with spacers I'm sure.
Old 01-20-2005 | 01:51 PM
4boltsiron's Avatar
4boltsiron
Default RE: Largest Rear Tire
not sure if you could do that or not but from what I understand it may not give you the "wide" look your after .They(who are "they" anyways?[sm=shades.gif]) say you need a wider rim to give a wider look.
Old 01-29-2005 | 12:23 PM
barhpr's Avatar
barhpr
they are kinda pricey but theres a 200 and i think a 250 swing arm you can buy.
Old 01-29-2005 | 02:15 PM
Steeltown's Avatar
Steeltown
You know just my opinion, but those big fat tires are very much a result of all the choppers shows out there today...i personally the old school thin look...just a thought....especially on a Sporty???
Old 01-29-2005 | 08:53 PM
Sincecrazy's Avatar
Sincecrazy
I agree with you on the wide rear tires, Its all out of proportion and overkill. On a funny note though, my wifes 2004 883 has more rear tire than my Roadking. Wider tires cost more, ride rougher, and with a contact patch of 3" at best, your wasting alot of rubber with each tire. However, If youre out for eye candy and bling, a wide tire looks great.
Old 02-01-2005 | 12:22 AM
Johnny's Avatar
Johnny
ORIGINAL: Steeltown
The 04 and 05 model sportsters have a 150mm tire in the rear.
The difference between the stock 130mm and a 150mm is only an inch.
Try this link for a 180mm wide tire kit.
http://www.chopperscycle.com/page/VTS/PROD/46-132/10892
Old 02-05-2005 | 09:01 AM
00hawg's Avatar
00hawg
If your sporty has a 130 tire on it like mine does, I was told by many aftermarket techs, that the biggest tire you can go up to is a 140. Anything bigger would rub or not fit. The 04 and 05 models have a complete different design in the rear and thus can accomidate the wider 150 tire.
Old 02-09-2005 | 01:49 AM
Tom.Mellett's Avatar
Tom.Mellett
2nd Gear
My buddy has a 94 Sporty with stock swing arm and a 150 on it. He did have to change it to chain drive though. Not sure how far you want to go. Good luck.
-Tom
Old 02-28-2005 | 12:18 AM
LIGHTEMUP's Avatar
LIGHTEMUP
Stage I
a 140 is as big as you can go but you can buy a wide swing arm kit that will fit up to a 180 but you will also need a 8.5 rear fender a 16x5 rim and a 180 tire of your choice
Old 03-01-2005 | 06:46 PM
scatterbrain's Avatar
scatterbrain
Realize that, all else being equal, going to a wider rear tire will make the bike slower-steering (less responsive).
Quick Reply: Largest Rear Tire
