Largest Rear Tire
Old 03-15-2005 | 10:48 PM
phoenix's Avatar
phoenix
Default RE: Largest Rear Tire
Put a 200 Avon on my 97 sporty- the only thing I had to change was the :frame,front end, tank, front tire, oil tank, forward control, handlebars-------------etc,etc,etc. Leave it alone unless you have too much time on your hands-not to mention about $6000 for the above custom parts. Did I mention Jockey shift , foot clutch and new up swept pipes? Its a work in progress- but then I have an o5 softail deluxe to ride.
IMHO you wont nitice the 150 tire and will have spent about $1000(paint incl) for your troubles.
[IMG]local://upfiles/717/545B833480384A879F6889BAFDED6DA6.jpg[/IMG]
Old 03-16-2005 | 07:59 AM
investorsc's Avatar
investorsc
Wider tires cost more, ride rougher,
I disagree that wide tires ride rougher......they actually take up more surface area, and absorb some of the smaller impacts...Even if the hit more bumbs (Wider track to expose to bumps- it softens the blow).....Ride a 60's chopper with that skinny *** O-Ring tire, them ride one of todays with a 240, 250, 300,330.....Today is smoother!
BRUCE
Cobrettysw
05-25-2013 01:16 PM
orangecrush
10-28-2011 08:59 AM
jbhawley
09-30-2010 03:25 AM
ShockwaveTXB
07-01-2008 12:20 PM
jd_underdog
07-06-2006 07:04 PM
Quick Reply: Largest Rear Tire
