Bassani Radial Sweepers Review
Also post the video of your Bassani on here....created this thread so other forum members could hear the different types of exhaust systems if they are in the market for an exhaust upgrade.
https://www.hdforums.com/forum/sport...videos-10.html
John
Don't know what the clutch pack is.. But I have a 2015 model. Was gonna turn the clutch adjuster nut on the front of the frame under the rubber boot to see if that resolves the issue.
Received 4,221 Likes
Just saw this thread.
Yes, the TTI's work. Whether you notice it or not, you picked up 7-12% in low and mid range torque. You will get a bit better MPG also, all things being equal (meaning you don't twist the throttle more to hear those bad boys). lol
Regarding your clutch, as hcsic mentioned, there is nothing that the TTI's do that could possibly affect your friction zone/clutch adjustment.
It either needs an adjustment on the cable (like you mentioned you're going to try), or an adjustment inside the derby cover (the cover you remove to refill your primary/transmission).
I really like the sound you're getting out of those Bassinis!
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
