Why do Sportys vibrate?
#51
Originally Posted by grbrown
Harleys going back into the mists of time have had rubber-mounted bars, so unless someone has changed yours they should be fine. They certainly shouldn't be uncomfortable to ride with.
#53
Some think that the balance cams in a TCb Softail motor refer to the valve cams but it refers to this driven off the crank. Most all modern large 4 cylinder car motor have balance cams. My Toyota 4x4 has two driven off the cam chain. My Honda CRV has them driven off and behind the oil pump
