Front Turn Signal Relocation Kit
Old 10-02-2015 | 11:59 PM
hscic's Avatar
hscic
Originally Posted by PanHeadRich
I never seen those short tree mounted signal relocators before. Nice & clean look. I'll have to get a set for my FXR. Thanks for posting guys.
Where are your turn signals....don't see them in the pics?
  #42
Old 10-03-2015 | 01:03 AM
hscic's Avatar
hscic
Completed the install. Thank you to all who assisted along the way.
Before relocation:
After relocation:
  #43
Old 10-03-2015 | 08:30 AM
Guzzi's Avatar
Guzzi
Looks great. What kit did you use?
  #44
Old 10-03-2015 | 09:49 AM
PanHeadRich's Avatar
PanHeadRich
I just finished the makeover on that bike and haven't put the signals back on yet. I've been trying to decide what to use and where to mount them. The huge stock lolipop signals just wont cut it. My hard bags have lights in them them that I'll use for the rear signals, and now I'll plan to use those tree mounts with the black sporty signals. I'm sure it will look and function great for me. Should work out perfect.
  #45
Old 10-03-2015 | 10:14 AM
hscic's Avatar
hscic
Good luck with your install. Yes they look great, better than on the handlebars. You will not be disappointed.
I also have built-in lights on my hard saddlebags, but I use them as additional brake lights and relocated my turn signal (integrated with my slanted license plate holder) since I also have quick release mounts for the bags and wanted to have turn signals if I remove and ride without the bags.....just a thought for you to consider.
  #46
Old 10-03-2015 | 10:17 AM
hscic's Avatar
hscic
Thanks. Check post #28 and #33 on this thread.
You will need to go to a hardware store to pick up a couple of socket allen head bolts and lock washers to secure the turn signal to the mount....not provided in the kit. I got 5/16-24 X 3/4" stainless steel, you can go longer or shorter depending on your set-up. HarleyScuba installed 1/2" spacers to extend the signals out a little more.
  #47
Old 10-03-2015 | 01:35 PM
ylwf3vr's Avatar
ylwf3vr
Front relocation looks great!!
  #48
Old 10-03-2015 | 01:41 PM
hscic's Avatar
hscic
Thanks ylwf3wr....got your cast off yet and back on the saddle?
  #49
Old 10-03-2015 | 07:21 PM
PanHeadRich
Sure, I understand you point. But my bags are a permanent fixture on my bike and part of the paint scheme. My bike is lifted pretty high and I don't personally care for the look of the gap between the rear tire and fender. So the bags are also doing a good job of concealing that gap. I'm also trying to keep it as clean and simple as possible. In doing so I'm going to install a Run, Turn, Brake controller that will light the bags and taillight as running lights. All three lights will also work as brake lights. And still allow the bag lights to flash as signal lights. That's the plan anyway, we'll see how that works out.
  #50
Old 10-03-2015 | 08:00 PM
hscic's Avatar
hscic
Cool....sounds like a plan.
Quick Reply: Front Turn Signal Relocation Kit
