LED Headlight
LED Headlight
Hello guys I have this drag spec headlight bike on my 48. I recently put on some tru wraps led turn signals that are bright white. The light is yellowish so I need some ideas on how to make this headlight white led or do I need to get a whole new headlight? Thanks for your help
LED bulb with integrated ballast. Should fit HD bucket....it did on my stock 5 /34" bucket.
http://dkcustomproducts.com/Premium-...-H4-HL-LED.htm
You could also relocate and change the headlight like I did. But the headlight came with a halogen bulb so changed it to LED.
http://dkcustomproducts.com/Modular-...HL-BRK-CHR.htm
Matching up light colours is rather like a dog chasing it's tail - likely to end up in a heap of fur! The Touring chaps get quite agitated on the subject, bearing in mind most of them start out with three white lights up front. Even different brands of LED lights are likely to be different in colour, not least because LEDs as vehicle lights are pretty new, just like HID was a few years ago and halogen were before them.
or a bulb like this, as an example :
Don't have one, haven't tried, just seen many cars driving with these "cool" blueish lights on.
I tried the PIIA bright white halogen. For a halogen, it is a great light. Uses the same voltage as stock but is similar to LED but without the ballast. Changed to LED since it uses a lot less voltage.
http://www.piaa.com/xtremewhite_powersports
