Turn signals
09-08-2015, 01:45 PM
Turn signals
I have a 2001 xl1200 custom and I'm trying to find out if a bad turn signal bulb in front or rear would make it so the signal didn't work all around. Also the hazard lights will not come on as well. Bulb or switch?
09-08-2015, 01:59 PM
Turn signals
If you had a bad bulb. Let's say front left then the rest would come in and stay on. And the other side should work normally.
But you can try bulbs first. They are cheaper and easier then the switch
09-08-2015, 02:01 PM
Okay yeah I was thinking switch just because if the front was out I figured rear would still work. Okay thanks
09-08-2015, 02:16 PM
Turn signals
Try the flasher first.
09-08-2015, 08:37 PM
frozeneyeball
04-24-2019 09:27 AM
Chriskunkle29
04-07-2016 12:06 PM
HD daddy
Electrical/Lighting/Alarm
02-24-2015 05:27 PM
duke
General Topics/Tech Tips
10-14-2003 11:02 PM
duke
10-13-2003 04:41 PM
