Sportster for Track Days?
I can not speak much for the mods that would be appropriate although I would point out that if youre doing a track day kind of deal you may be scraping pegs a lot. Anytime I go out with the sole intention of using the sides of my tires I always scrap which is why had to get a high exhaust. Just my two cents. If youre just trying to have fun then it could be fun but if you really enjoy pushing it then maybe changing up the suspension to make it higher / rear sets would be something to think about.
I've had mine on Roebling Road here in Savannah (Just west a few miles actually.).
I'm not the fastest guy on the track, but not the slowest. My fast days were on MX, flat track and SuperMoto bikes. I prefer controlled loss of traction to the precision of road racing, but I hold my own amongst amateurs.
That said, the inline four sport bikes simply have much more speed than my 1259 kitted cafe bike. No contest when they launch ahead in the straight sections. Cams and beadwork might lessen the gap, but modern 600cc, 400lbs race replicas are just too quick and fast for a 500lbs 5-speed twin.
But the Sportster is still a lot of fun once you get ground clearance. Mine has 15" shocks, rearsets and a pipe that's tucked in a bit. The bike doesn't touch down.
It does flop around though. The forks are totally inadequate for fast direction changes. This, unfortunately, is the limiting factor. Even with decent internals, the forks flex all over when pushed hard. It could be much better with upside down sport bike forks.
Surprisingly, the brakes are OK. Not great, but functional. I'm sure they would fade if in the track for long periods.
At the end of the day, I had fun and was still challenged, just at a slower pace than the modern race replicas.
If "fast" is your goal, get a different bike. If going faster than your last lap is desired, the Sportster can be as good a choice as any with some well placed mods.
I don't care if the bike would be fastest (not expectin to keep up w/ a 200 hp sportsbike) as long as it would be fast enough & handle good enough for me to have fun as well as provide a platform on which I can learn how to ride better. BTW, I also have a KTM 625 Supermoto that I don't ride as well as I should and want to track that as well.
And Ive often said sportys have pretty damm good brakes, if anything their fault is fading from repeated hard braking, but they have more than enough stopping power.
A typical Sportster can be easily over ridden on the track.
As mentioned above...ground clearance/ lean angle is your biggest issue.
Yes, XR1200 or Buell would be a better Harley trackday bike, else open your wallet as you modify a typical XL for track.
Try a Ninja 300 instead...good luck in your decision.
Is there any reason I could not start w/ any sportster & mod it into n XR1200X? Or, would I be $$$ ahead just to buy an XR. Part of the fun for me would be to work on the bike.
The geometry of the bike is a different story, however. You can put upswept pipes on, change rake and trail, change wheels, etc. all day long.
I think it'd still be satisfying enough to find a used XR, fix anything that might be wrong with it, and then modify it so it fits your personal riding style. Change gear ratios, valve timing, seating position, geometry, and so on, until you get it dialed in.
