Replacing Brake Pads??
RE: Replacing Brake Pads??
There is one pitfall I stumbled into. The paper instruction slip included with the pads had a mistaken instruction as regards installing the FRONT pad (rear pad instructions were OK).As I recall, the slip had a picture that points to the wrong bolts to loosen. It pointed to the bolts that held the parts of the caliper together, rather than to the brake pad pins that hold the pads in place. Even though I doubted the instructions at the time, I decided to follow the instructions on the slip. I ended up loosening the wrong ones and allowed some brake fluid to leak out, requiring me to add more and bleed the front brake. I called HD to alert them to the problem. They said they were aware of it, and that I could get correct instructions at the dealer!!!
If there is a conflict between the manual and the instruction slip, go with the manual.
Did you remove the Cap on the reservoir? I use a long skinny screw driver as a kinda pry bar, gently of course
There are two pitfalls on the front brake. Haven't done the rear so don't know.
First, there is a screw that holds the inside pad to the cover plate that faces the wheel. Do not tighten this too tight or it will strip very easy. Use locktite instead. Do it right or the plate will fall off. Finding another is hit and miss at best.
Second. The brake pad spring clip fits in a very non-obvious way. It folds back over the top of the pad and forces it down. It does not hold the pad directly.The drawing showing this sucks.
I expect there are similar issues with the rear pads.
