Turn Signal help!!!!
Old 05-01-2007 | 05:36 PM
s2kmaniac81's Avatar
s2kmaniac81
Default Turn Signal help!!!!
This is a 2 part question. First, I bought a 1998 1200 custom and, love the bike, but when I bought it, it already had the red back turn signal conversion or so I thought. The only thing that works are the turn signals. I would like to know how to hook them up so they are break lights also. I pretty sure I have to buy a kit to do, but can't find on anywhere. Can someone please direct me in the way of a website or someone I can find one of these kits.
Ok, part 2! Yesterday I went to autozone and bought some replacement LED lights for the brake lights, and rear turn signals. I bought the dual contact 1157 replacement lights. When I installed them, they wouldn't work correctly. When I hit the signal button they came on and stayed on constantly, they wouldnt blink. Also I pretty sure this is a quality issue, but they one I installed in the brake light wasn;t that bright. So I put all the old one's back in and took the LED lights back to the store.
Now, why did the LED's not blink, also I thought they were suppose to be brighter than incadesent bulbs? Where could I go to find some bright plug and playLEDlights? Any help would be greatly appreciated
Old 05-01-2007 | 05:53 PM
cHarley's Avatar
cHarley
Default RE: Turn Signal help!!!!
Ok, for part 1, look into the tail/brake/turn signal kit from Kurayakn. I put it on mine & it works great. It's about $60 for your bike, 04 & up require an additional adapter cable for about $15.
Part2, if you are going to use LED lamps the Kurayakn kit requires a current compensator (comes with kit) to be installed. If your bike has a module already installed you might not have the compensator which would keep the lights from functioning properly.
Old 05-01-2007 | 05:56 PM
s2kmaniac81
Ok, I will check into that then, thanks for your help.
Old 05-02-2007 | 01:08 AM
Pilotguy1050's Avatar
Pilotguy1050
Those of us who have already tried LEDs for brake lights have been disappointed. I even had a cop pull me over one night, and told me to GET RID OF THOSE LEDS or GET A TICKET.
I went right home and did that, as I had thought they were limp-d**k anyway. I have yet to find anything that I'm willing to risk my hard-earned cash for unless I can see someone else's REAL BIKE in a REAL APPLICATION that looks brighter than original incandescent bulbs.
Anyway, good luck if you find a success story; just don't be optimistic.
Old 05-02-2007 | 01:12 AM
Wolhar's Avatar
Wolhar
ORIGINAL: cHarley
05 does not require anything other than the Module if ya buy the HD item and it was 54 bucks for my 05, plug and play, run/turn/brake, and you are right on about the compensator for the LED's.
Old 05-02-2007 | 05:26 AM
cHarley's Avatar
cHarley
ORIGINAL: ******
The difference between the HD & Kurayakn units is that the Kurayakn has a jumper option that causes the tail lights to quickly flash 3 times and then go solid on when the brake is applied. It does seem to get the cagers attention.
JAGlide
07-28-2018 05:59 PM
Revenuer
Electrical/Lighting/Alarm
06-01-2012 03:38 AM
RodFarmer
08-09-2009 06:52 PM
bberck
07-16-2009 03:48 PM
Quick Reply: Turn Signal help!!!!
