nOob needs help.
nOob needs help.
ok. Ill give as much details as i can.
Here are the issues..as well as the situations in which the issues arise.
2012 Sportster 1200 CP
At first it was the check engine light. It will come on for a few seconds after starting the bike, then go out.
Then i noticed the battery light AND engine light would come on...BUT..it only did it if i was sitting in traffic, and if i got on the freeway..after a few mins they would both go out. So i attributed it to the heat..BECAUSE it does NOT do it if i ride it at night or early in the morning. I live in Phoenix BTW Its been 105+ for over a month.
So i thought maybe, when i changed the oil, i used the wrong oil, and its getting too hot. Because the symptoms were only showing up when its real hot. So i changed to a full synth heavier oil. But its still doing it.
There were times when, if i turned off the bike...it would not restart.
just click click click click from the area of the starter. there WAS juice, as the lights and everything else worked fine. I had to push start. Rode it all the way home...engine/battery light still on. Let it sit overnight. Bang, fired up in morning no probs. So thats why i assumed its heat related.
So now i have no idea. I figured out how to check the code.
its P0562. I have searched that on the web, but dont see how the heat affects the stator or voltage etc.
Im trying to figure this out, as i do not have the $$ im sure the dealership is going to want. i might just have a nice 2 wheeled ornament for my parking spot for the next year or so.
Any help would be greatly appreciated.
A couple years ago, I got the same code and was getting the check engine and battery light at the same time. I had a loose ground connection on the battery, which I assumed vibrated loose, added a lock washer and haven't had an issue since.
FYI, it's normal for the yellow check engine to come on when you start the engine, it should go out after 5 seconds or so. If it comes on a second time, that means you have a trouble code stored.
nOob needs help.
It sounds like you have either:
A loose battery connection.
A loose ground wire (the other end of the negative battery cable.)
Or,
One of your battery cables (probably ground) has gotten too hot too many times and is not conducting well when it reaches a certain temperature.
Or,
As you probably know that's a low system voltage code. Do you have a digital voltage meter? Stick it across the terminals and check your battery voltage, should be 12.6 volts.
Now with a 20v setting start the bike and put the meter on the terminals again. I'm no harley guy but normally on any vehicle you would be looking for 13.8 to 14.4 volts. If you're not getting that then I'd suspect you have a alternator/regulator problem. We can look into checking those outputs...
If me were thee, i'd still do some checks as there's nothing worse than getting stranded roadside.
We can only help you if you follow suggestions! You have several above, so check them out. If in any doubt about your charging circuit go to the Tech Electrical section where you will find two helpful Stickies. Go through them carefully and report back.
