High speed wobble in corners!
Worked on a friends bike recently that had those symptoms, turned out to be a busted fork seal on one side and because of that the fork oil level was uneven. Removed, cleaned, replaced seals both sides, added fresh oil and problem gone.
Check rear tire also, pressure and or uneven wear. The rear tire has lots to do with turning more than people realize.
Your wobble may be linked, but the suggestions above between them may help. Also check tyre wear and pressures, for both tyres. If you have aftermarket tyres check that brand's website, as the pressures may be different to stock tyres.
Well if no hi speed wobble in a straight away it could be suspension - what can be termed "wallowing" in corners.
Rule out that the steering stem bearings are correctly adjusted, swing arm pivot is torqued and both axles torqued. Just in case check the brake rotors and rims for trueness.
Tires can also be most suspect. Broken motor mount could also cause this issue.
To answer your question directly...maybe (maybe) fork springs will help. Sportster all seem to benefit from upgraded front and rear suspension.
Good luck.
Good luck.
