Auxiliary Switch??
Sorry, my previous post was misleading. You don't loose the horn or headlight switch, this is an add-on.
Here's a link to the install instructions.
Well that looks nice, as I have also wanted to add a switch.
Mainly to be able to turn off headlight when engine is running if I want to.
Also working on getting the headlight relay kit installed (finally) which with this switch would make it all a lot easier.
As all I have to do with this switch is to have one ON/OFF switch mounted, and use that for cutting the ground of the relay kit, and the lights either work or don't.
There is a switch for that housing too :
http://www.harley-davidson.com/store...ontent=Default
